Show us your non-modeller ampless live rig
  • stickyfiddlestickyfiddle Frets: 27269
    Cool.
    You still need a good envelope filter though!
    No such thing!! :P
  • KeefyKeefy Frets: 2324
    After a brief dalliance with the DSM & Humboldt Simplifier MkII I have returned to the RevivalDrive. (I liked the Simplifier, but not as much as I like the Origin stuff.) I briefly tried my BassRig '64 set to a tweed Bassman, but I didn't care for what it did to the top end.
    In place of the Two Notes Torpedo CAB I'm now using a Palmer PDI-09 for speaker simulation, and a Walrus Fundamental Reverb for, er, reverb. I had previously discounted speaker sim DI boxes based on my experiences when I first got an RD pedal, but having tried the the Palmer again I find it works brilliantly well. I have dialled in a nice Spring sound on the Walrus, and now have a range of sounds that I can be proud of. I'm looking forward to gigging this tomorrow night when I stand in on rhythm guitar with Dire Streets.
  • TheBigDipperTheBigDipper Frets: 4815
    edited February 9
    Since dumping the GTkCore, Mobius and TU-3, my board looks a bit big. The RDC, Spark and Ridge are in loops on the ES-5, as is one path through the H90. The other path of the H90 is after the ES-5 and that then feeds the Ampster. The Ampster is set for a clean tone, but slightly gritty if I dig in.
    https://www.dropbox.com/scl/fi/7ys8ae6dcc4q2bmk9dlle/New-Board.JPG?rlkey=xub05l4yvuiiqe5r6o23b5ym3&raw=1
    I can go balanced direct into the desk from the Ampster with a choice of 2 analogue cab emulations and/or directly into  a guitar amp without going through the Ampster circuit at all.
    Ooh I hadn't come across the Carl Martin Ampster before.
    I've had three different analogue direct amp solutions on this board in the last 9 months and this is the one I like best. Quilter Superblock US, Simplfier Mk II and now the Ampster.
  • rze99rze99 Frets: 2369
  • CarbonCopyCarbonCopy Frets: 232
    rze99 said:
    I should try one of these. I had the Tech21 Blonde which I think these are based on and didn't like it, but worth trying this instead.
    Do you use it with any other pedals into the PA or just guitar>American Sound>PA. What type of music do you play?
  • NickBNickB Frets: 266
    edited February 10
    This is my rig which is using the HX Stomp as fuzz, modulations, delays and reverb. The Simplifier is set to the Fender setting. I haven't switched on my Cornell Romany 12 or Rift Blonde Bassman for over a month. I can do a wet dry with another amp as the Simplifier has a thru output.
    https://live.staticflickr.com/65535/53520536154_13c23a9c5a_b.jpg
    Very neat!
    Keefy said:
    Very neat!
    I won’t show you the underside. The DSM Simplifier MKii is properly good!
    One thing I wish I’d checked beforehand was the output level from the Palmer DI. I split it between one input of my IEM transmitter and the PA, so I always have my own monitor signal in my earphones. Unfortunately it’s quite low, so I had to do some tweaking of settings on the transmitter and receiver to get a reasonable balance. I’m going to try a couple of alternative cab sim solutions;
    (1) Sonicake IR ordered from eBay - inexpensive IR loader with both 1/4in jack and XLR outputs.
    (2) Runoff Groove Condor - DIY build analog cab sim, to which I’ll add a balanced line output via a transformer. I have all the parts for this except for a particular J-FET, also now ordered.
    It does feel like a never-ending quest to achieve the best solution!
    The Ampster has developed a couple of faults, so it's on it's way back to GAK for review. In the meantime, I've already got an RDC on the board for overdrives/distortion. I can get acceptably close to those overdrives with the Ridge and I have a PDI-09 in my gigbox. Hmmm.... What I do not want to do is put the GT1000Core back on just for amp/cab sounds.
    And it really is a never-ending quest. isn't it? I'm not looking for convenience with a "go direct" solution, I'm looking to take as much control as I can for my live sound without having to listen to fizzy amp modellers and IRs.
  • abw1989abw1989 Frets: 641
    Going to be travelling a fair bit in the upcoming so decided to make a do-it-all board:
    Tuner > Pitch Box > Magus > Stomp > IronHeart> Stomp > IronHeart then straight to cab
    The Stomp and IronHeart live in 4CM so I can have blocks in front of and in the FX loop of the IronHeart.
    Hotone used to add extra footswitches to the Stomp.
  • No pix (sorry) but I seem to be working quite well with the RevivalDrive Compact giving me edge-of-breakup Voxy sort of tones that clean up with the guitar volume knob, running into a Neunaber Iconoclast cab emulator. Other tones require overdrive, etc. and I don't need JC/Twin cleans. The Palmer PDI-09 worked well, too, but the Iconoclast is a bit nicer, has stereo outputs and a headphone amp.
    Despite it being outside the time limit for refunds, GAK offered me a cash refund for the Ampster. As the RDC was working fine, that's what I did. Thank you GAK. Although, if it hadn't become faulty, I'd still be using it happily.
  • 57Deluxe57Deluxe Frets: 7345
    here you go...
    <Vintage BOSS Upgrades>
  • BrioBrio Frets: 1880
    edited March 3
    Amps from the ToneX the rest from the GTK Core. I have all the Origin Effects amp sims and all have been on the board at times.
    Left fs for patch changes, rh fs for tap tempo and reverb on/off.
    This frees the GTK buttons for effect switching.
    https://flic.kr/p/2oPiiBJ
  • FezFez Frets: 536
    What cab are you using with that?
    Don't touch that dial.
  • FezFez Frets: 536
    57Deluxe said:
    here you go...
    Boss ME5 & Kay wah cor they bring back memories.
  • Matt_McGMatt_McG Frets: 328
    @NickB that board is very nice. How do you find the M-EQ driver? And does it offer anything you can't get with an HX Stomp block? I ask because I also use a Stomp with extra pedals, and am always curious about what works well as a boost/drive/tone-sweetening kind of solution. At the moment, that tends to be a compressor with a bit of "push".
    @Fez - what ever I can find haha!
    At the studio we practice in it's usually an aging Marshall 4x12 or a Line6 4x12. At home my H&K 2x12.
