Montys "ageing wax" snake oil? or good ?
  • Mike58Mike58 Frets: 162
    i had a top tip from a luthier that Briwax 400g Original Dark Oak does the same exact thing and one tin has lasted him 20 years!
    Ha my trusted luthier uses and said the same thing to me lol
    Cheap here
    https://www.dunelm.com/product/briwax-400g-original-dark-oak-1000188611
  • thermionicthermionic Frets: 9671
    edited February 10
    Well, I bought a pot last week and it arrived on Friday. I have a few guitars that may benefit, but top of the list was my Squier Classic Vibe Jazz Bass - one of the earlier Chinese ones and the specs of these say the fretboard is rosewood. Mine has streaks of lighter and darker wood. I cleaned it with isopropanol (I didn’t have lighter fluid but IPA is a pretty good solvent) - pretty sure that the last time I applied any oil to it was about ten years ago anyway! I then applied a first coat and rubbed it off after five hours. There was a noticeable difference, so I applied another three coats, buffing most off before applying the next and letting it sit. All in all, the wax sat on the board for around six hours.
    https://i.imgur.com/eVyA5Gn.jpg
    I would definitely say that it’s worth doing, although I’m sure some pieces of wood will take it better than others. In the flesh it looks much better than the comparison photos.
    https://i.imgur.com/u1khfrr.jpg
  • nero1701nero1701 Frets: 1462
    So, how far did the tin get guys?
  • fretfinderfretfinder Frets: 5059
    Your luthier uses and yet you still trust him?!  ;)  :o
  • inewhaminewham Frets: 150
    A word of caution on the dubbin, it often contains neatsfoot oil which can get smelly when the weather warms up.
    ( I used  neatsfoot on my bike leathers as a youth, it made them waterproof in winter but they smelled like rancid lard by the summer )
    Ian
  • robertyroberty Frets: 10893
    Oh I have a pot of this. I used it on my H-535 the other day, kept it on overnight. I don't have a photo but was a little pale and sad looking before. It looks much healthier now, moisturised
  • ReverendReverend Frets: 5006
    I have finished using it. Who is next?
  • munckeemunckee Frets: 12415
    Could I have a try @Reverend, although I'm not sure what the deal is?
    use it, do a neck or 2 and then send it to the next in line, or the next person to ask for it.
  • OilCityPickupsOilCityPickups Frets: 10593
    The brand I showed contains no neatsfoot
  • Philly_QPhilly_Q Frets: 23036
    I stumbled on this video the other day.  The guy uses an absolutely ridiculous amount of wax, which for some reason made me feel quite queasy.  It also made me distrust any other advice which may be given on his channel.
    Received thanks @Reverend I will give it a go on my pau ferro jazzmaster fretboard and post the results!
  • hotpickupshotpickups Frets: 1822
    edited March 28
    Your luthier uses and yet you still trust him?!    o
    Yep. He’s the most talented luthier I’ve ever met. A great player too so he knows what’s real and what is snake oil etc
  • paulmapp8306paulmapp8306 Frets: 847
    This still is actually really really good.  Its bees wax with a few other natural ingredients.   REsult is better than lemon oil for sure.
    Mick (TPS) uses it - so I was perfectly happy to try it.  Wouldnt use the OP version though personally, but my boards dont need darkening.
  • Tele37Tele37 Frets: 28
    edited March 29
    I was under the impression that using wax on a fingerboard is a bad idea as it can repel glue, so if it gets under the frets and in to the fret slots you have problems later on with re-fretting / repairs.
    I could be wrong, so can any luthiers chip in here with advice?
    @felineguitars?
    Thanks!
  • drwiddlydrwiddly Frets: 918
    AFAIK frets aren’t normally glued in (unless you have a Parker Fly)?
  • elstoofelstoof Frets: 2513
    Wax doesn’t penetrate, it’s too solid for capillary action so so t get anywhere near your feet tangs
    edited March 29
    Yeah, loads of manufactures do it, it seems. I know PRS, Suhr, and most luthiers glue frets in.
    I think the instrument food is much thinner than regular beeswax, it can definitely get under the frets, especially if they aren’t perfectly seated. Also, what about fingerboard repairs?
    I think the instrument good is much thinner than regular beeswax, it can definitely get under the frets, especially if they aren’t perfectly seated. Also, what about fingerboard repairs?
    Fwiw, I've used this on my PRS, and I'm collecting it tomorrow after a refret.   Didn't seem to be a problem for the Luther.
  • guitarjack66guitarjack66 Frets: 1888
    I still use Dubbin on my football boots as I referee most weekends and those boots (adidas copa mundial) are almost 20 years old.
