Paoletti & John Cruz
124»
  • WhitecatWhitecat Frets: 5452
    elstoof said:
    I’m not sure I buy the chestnut wine barrel story, how do you get a strat body out of these?
    Of course you could glue up a number of staves, but it wouldn’t look like this 1 piece body
    1) that is not a one piece body - it's at least two, maybe three - would need to see the end grain to tell for sure
    2) the staves used in wine barrels used for aging are MUCH wider than the ones you picture above - the barrels can be like 300l each - e.g. https://www.polsinelli.it/en/chestnut-barrel-300-l-with-manhole-P1851.htm - they are not designed to be "mobile" in the sense that they are strictly filled for aging wine, not transporting it. So they use bigger planks to make them.
  • CHRISB50CHRISB50 Frets: 4324
    Looks like a 2 piece. You can see the join in the middle. where the grain is misaligned.
    I think that’s most likely but with that type of grain you could do a join at the very bottom where the lines are parallel that would be virtually invisible if you had to. Reclaimed wood doesn’t always generate matching-width boards… but yeah, *probably* 2, outlier chance of 3.
  • guitars4youguitars4you Frets: 14384
    Take a line, south, from the G+D intonation screw and certainly see a line there - I keep looking at the bass side - Take a line, south, from the scratchplate screw, Low E side, near bridge pick-up - And wonder if I can see a line or not - But as said above, normally a view from the rim tells all
  • digitalkettledigitalkettle Frets: 3307
    Philly_Q said:
    As played by Pino(t) "Grigio" Palladino.
    No, I know.  That was shit.  I apologise.
    Quit wining!
  • skullfunkerryskullfunkerry Frets: 4205
    I actually really like Rob Chapman's Alfa, even the relicing. Those shotgun shell knobs would be straight in the bin though, and I'd prefer a hardtail or a Floyd I reckon. The body, neck & headstock look great to me though, and HS is my favourite pickup combination.
  • mgawmgaw Frets: 5296
    I just really like Rob Chapman
    Me too. I think he'd be good to have a pint with.
