I just realised the Scimitar GTE had the same 2.9L Cologne engine as Transit ambulances back in 1991 in the brief period before the turbo diesels were introduced. Word is the Granada BOA 2.9 Cosworth was built for 350bhp but the car couldn't handle it so it was lowered, but the bottom end of the engine can if you wish to twin turbo it. It also just bolts in a Transit with the old Transit 2.9L cologne adaptor plate and engine mounts.
(formerly miserneil)
I had a Consul back in the '70's but it was a very dull grey colour.
Later had a MKIII Zodiac I converted into a pick up.
@Neil, this one used to be the classic 'Battleship' Grey but was re-sprayed before my ownership.
Drum brakes, column change, bench seat and vacuum wipers, a joy! :-)
Eddie Cochran was killed in a Ford Consul in Box so no more Rock n' Roll credentials needed for the humble Ford! :-)
Quite a successful day today!
Weather was good enough to push the engine outside, and start cleaning it up.
I then had a good look at the broken bolt issue. Decided I was going to drill and tap it out to M10, then use a 10mm stud. I will need to relieve the new engine mount with a grinder a little bit, but it's eminently do-able. Having drilled it, I decided it definitely needs to be filled with some epoxy, so I've used Devcon alloy paste, and forced it into the hole as best I can. It'll take a few days to go off completely, but I think there's enough good casting for the tap to bite into, and it should support the stud reasonably well.
http://i232.photobucket.com/albums/ee189/chillidoggy/Lotus/2015-02-08133201_zpsa6a2e0a1.jpg
http://i232.photobucket.com/albums/ee189/chillidoggy/Lotus/2015-02-08133109_zps5630f446.jpg
http://i232.photobucket.com/albums/ee189/chillidoggy/Lotus/2015-02-08124320_zps034f6997.jpg
http://i232.photobucket.com/albums/ee189/chillidoggy/Lotus/2015-02-08124302_zps07b53c65.jpg
http://i16.photobucket.com/albums/b22/MattD252/Mobile Uploads/28022010132_1.jpg
My two classics, the one of which I still own (Mini).
I had the Cortina years ago, sold it in about 2004. I spent most of my student loan doing it up and it was the coolest car in the uni car park. Road tripped it to Cornwall as well - awesome car, even as a lowly 1.6L 1975 round headlamped model.
I bought the Mini 6 years ago - it was MOT'd and as I found out, someone's unfinished project. The MOT ran out as I drove it around, and wound up undoing all the previous owner's bodges. I still have it; I ran it around for a while in 2011 after getting it back on the road, and it's been dormant in my garage for the past 2 years or so. Need to find the motivation to get out there and sort it out.
Or chop it out for a Gibson Custom Shop LPJ!!!
