The comment about SS not competing with drummers is just bizarre. Just ask anyone with a PA system or a bass player with a modern amp.
I can't find anything
Neither of those things are guitars though Fine if it's not an issue for you mate (and for certain types of music it really isn't' . It is for me for what I play and I'm sure other players must feel the same way?
This looks amazing.
the thing with the Axe that puts folk of is that it's "so complex"..
thing is.. it don't need to be.. it's up to you [the preset creator].. if you just want amp / cab and maybe a stomp or two, then build presets like that.. it's really simple.. but if you have needs that are a bit more exotic, you can just go mental with the config, line up all the hoops and I'd expect the Axe will be able to jump through pretty much all of them..
