And I'm kinda wondering why that is...
I'd really like to try one out, but I think it's maybe slightly telling?
If the features would suit you then I would definitely try one.
https://dl.dropboxusercontent.com/u/630473/gsp1101_glitch.mp3
Really quite annoying to be honest. Gotta re-think.
thats a pretty quick change fella,i think the only way to make it less of an issue is to running the fx unit in parallel,not quite sure how you'd achieve that though
It sounded quite good! Using another amp dedicated to cleans could definitely be an option for me, and would leave me to put a noise-gate in the FX loop of the EVH, so when I'm not routed to it, it's completely silent.
I even thought about a cheapy Pod 2.0 modeller plus some kind of solid-state power amp going out into 8ohms. Something like the EHX 44 Caliber; portable as fuck, but loud enough for my clean tones.
Nasty ground loop though. I imagine I need a proper ABY box with a ground lift on one of the outputs?? Like the Radial ABY box??
ME,thats one of the reasons i sold it so quick
The only other thing I was really using the GSP for was to replace the clean channel. All in all... a good distortion pedal will solve this. Set the amp for clean+high gain... use pedal for mid-tones.
You have a backup by default for gigs. Okay, not the same, but when a nightmare happens... Having a simple 50-100 watt power amp (isp do one that's quite small but probably more reliable than the ehx) and a pod means you'll have everything you need to just about get by.
