Ive had The Boot Chip and a PSU off of them well beyond the warranty expiration, buckshee too.
Nice people.
I also asked which fan I should purchase because my original one was very noisy. Included in the shipping box was a brand new silent fan that they'd just added for free.
You can't beat customer service like that!
There's plenty who could learn from G66.
Quantum 1.06 is out - only a new Ac30 model
Release Notes:
1.06
Improved screen grid modeling accuracy.
Added “Class-A 30W Brt” amp model based on the Bright channel of a non-Top Boost Vox AC30.
Added Scene indicator to Output and FX Loop GUI. The ‘A’ Quick Control knob can be used to select the desired scene while in the menu. This facilitates setting output levels in each scene.
Fixed wrong cathode follower default values in Class-A 15W TB, Class-A 30W TB, Hot Kitty and Matchbox D-30 amp models. Existing presets will be automatically updated with the new default values.*
*The range of the CF Ratio parameter has been expanded and all existing presets will have the parameter reset to default values. If you have changed the CF Ratio value in your presets you will need to re-enter the value.
Ebay mark7777_1
I've not noticed a difference between 1.05 and 1.06
my amp choices are: Herbert, VH4, 5153 mostly
