Or do you mean through pedals that you have in the loop?
My knob is fully engaged as I was advised that leads to unity gain. Discovered last night that by reducing the return block to -5db the clipping goes
The clipping was via 4cm in the Helix.
No it is at unity about 1 o'clock Full up is way too hot (obviously it's patch dependent)
What does the Helix sound like if you turn that effect off?
5 pedals BESIDES the Helix ? What are those 5 things that them there pedals do better then ? Is that an SP Compressor I sees ?
The three drive pedals... Well, like a lot of us I've been through a shit load of drive pedals but I never ever ended up with an OCD or Timmt or Rat or basically any of the drive pedals in the Helix so even though some of them are pretty good I'm going to stick with the ones that took me 20 years to settle on!
The other thing is a Lovepedal Vibronaut. The vibe on the Helix just doesn't do it for me whereas that pedal literally makes me a little giddy
That's ok though because when the Zendrive gets switched on there will only ever be a bit of reverb or short delay and that's it. Shits about to go down :')
I expect to see your Helix in the Classifieds also....soon! What DO you actually use and like in the Helix on a regular basis ?
I've only recently got the Helix but things I've been using are:
Throaty wah- A/B'd it against my Buddy Guy and RMC Picture wah and I think I might actually prefer it
Deluxe Compressor- great compressor, will still use this for certain applications
Tape Delay for general delay purposes and the Elephant Man for everything else
Chorus is great and I prefer it to the 70's one which is strange because I usually go for Ce1 emulations
63 Spring reverb
Script Phaser is great
Amp model wise I've been using the Soldano clean and crunch live. I haven't knocked up a cable for it to change my Cornford channels yet so I was using the Soldano clean and my amp dirty channel with a high and low cut on the Soldano but not on the amp channel and switching between them with one button in a patch
I also like the Bogner shiva amp model, the Plexi brt (squirelly bits aside) and the Matchless channel 1.
Mainly I like the big fuck off screen, the ease of use, USB audio and the flexibility.
