Line 6 Helix
1148149151153154427
    Cabicular;1140635" said:
    Lol "B Rig"!!!! Some nice units on there!
    If you add it up it gets more expensive than the Helix and a lot less flexible.
    I loved my pedalboard and I do like a new pedal... but live it just isn't as useable
    I'm too used to the luxury of expression pedals etc
    Marky says hi
  • johnonguitarjohnonguitar Frets: 1243
    If you add it up it gets more expensive than the Helix and a lot less flexible.I loved my pedalboard and I do like a new pedal... but live it just isn't as useableI'm too used to the luxury of expression pedals etcMarky says hi
    Is that Pedalboard Mark? Hi Pedalboard Mark!
    I should have taken a pic of his pedalboard
    It's got a tuner, a big muff and a mark bass DI
    He had a dod envelope filter but he took it off
  • siremoonsiremoon Frets: 1524
    Firmware V2.00 is now out.  Seems to have loads of stuff in it.
    “He is like a man with a fork in a world of soup.” - Noel Gallagher
  • SporkySporky Frets: 28739
    Including snapshots, which seem to be scenes. Nice.
  • fretmeisterfretmeister Frets: 24659
    Oooo! I'll have to update at the weekend!
    Oooooooohhhhh
    it is pretty cool actually
    snapshots really make a difference if you like that kind of thing
    snapshots can be used to change parameters as well as switching stuff on and off
    right who is updating first and gonna tell me if the 2204 is a belter or not? and squirrel free.... or do i have to do it myself?
    I'm going to do it this evening.
    i caaaaaaaaaant wait that loooooonggggg.... right I'm putting the kids in the car and going to my mums. Ill report back in an hour or two
    I've done it but I was in the middle of fixing a monitor wedge so didn't have time to flick through the new stuff much
    Then when I was screwing the speaker back into the baffle I slipped and put my screwdriver through the cone
    I went to bed for an angry sleep after that
  • FarleyUKFarleyUK Frets: 2442
    Updated, but don't use the in built amps. People are saying it sounds like Line 6 have somehow made everything sound tighter as well....
    I've found a couple of snags with Snapshots though:
    1. My snapshot 1 has a delay block that has the time param controlled by EXP2. However, in snapshot 2, I want the delay time to be locked to a specific time; doesn't look like this is possible.
    2. I use MIDI to connect to my JVM410HJS and change channels etc. Previously I used Program Changes but was advised to use the CC messages in Command Center (as the PC messages are not stored uniquely across setlists - so any PC messages on 01A of setlist 3 will be the same for 01A of setlist 4 etc.). However, the CC messages in Command Center on Snapshots will not let me change the CC# between snapshots - only the value.
    Could (1) be solved by having two delay blocks, one fixed and the other set by EXP2, and then switch between 'em?
    I'm sorry I can't help with any of the midi stuff I've only done the basics so far
    ....I reckon so! Will try it, cheers :)
    However, if the midi changes won't work, I can't use snapshots :(
    i love that Line 6 has just dropped this new term "snapshot" and already its like this new lexicon... id have called it "silly sausages" or something just to fuck with people
    oooooooouch
    Yeah I managed to convert a loose wire into an entire speaker replacement :)
    Go me!
