New Fender Pro Jazzmaster/Jaguar/Stratocaster/Telecaster
  • MossMoss Frets: 2409
    Nice colours, but the Jazzmaster seems to be a bit 'in-between' - it's like they're trying to win over both the modern and vintage crowds but failing at both
    Stop crying, start buying
    I wonder how many people they have in their design committee whose views they needed to compromise for.....
  • Mystic seafoam is a nice colour. Maple board though? Looks weeeeird.
    I really like maple fretboards on Jazzmasters
  • SporkySporky Frets: 28715
    I think it'd work if it had a BWB board.
    The pickup switch should either be in the normal place or closer to the point of the scratchplate though.
  • I don't abjectly dislike it, it just looks really irregular. Bet they're bloody bright, too.
  • WhitecatWhitecat Frets: 5452
    Can't believe how uninteresting these are... and I loves me some offset Fenders...
  • LoobsLoobs Frets: 3835
    edited November 2016
    These are less appealing than the Mexican/MIJ offsets. I'd take the 60s lacquer JM or Jag over this.
  • As someone with a blacktop Jazzmaster with the toggle switch on the lower half; I actually reckon that new placement is much more sensible and I'd be far less likely to keep smacking into it there.
    Me too. Just wish they'd offer these colours on the AVRI
    I do like the 3-way toggle switch on the Jaguars. With a rosewood fingerboard it'd look quite nice.
    All the other models are available with RW fretboards according to what's been posted, so I'd be very surprised if the Jag didn't too.
    It's actually a 4-way switch on this model- neck, neck & bridge parallel, bridge, neck & bridge series. The upper horn switch is a pickup phase switch. So slightly more versatile than the original switching, and quite likely simpler to use too.
    Don't like the switch placement on the Jazzmaster though- I'd have preferred it where it's meant to be, but if they really had to move it up there it should at least be equidistant from the edges of the scratchplate.
  • BabonesBabones Frets: 1207
    My thoughts exactly. Really odd placement.It's not even well placed up there. I wonder how many will rewire it below. I'd imagine some people might even play/strum round that area.
  • impmannimpmann Frets: 12678
    Hasn't the AVRI been discontinued, or did I dream that?
  • TeetonetalTeetonetal Frets: 7815
    Still on Fender.com
    Edit: though out of stock...
  • Isn't it the AV65 these days, rather than the '62 AVRI of old? Certainly on the JM. Not sure if the Jags with bound boards were also called the AV65 series or something else.
    They were indeed.
    Fender seems to vary which "years" they "do" with the AVRIs now. It was '65 recently but also '59 and I think '61 as well.
    Nice guitars but almost too period-accurate in some cases... I'd still prefer a flatter radius on top of all the other vintage-spec stuff. That's where the Custom Shop starts to look good... but that's probably the idea.
    antique green Jag w/ rw board would be nice.
    BOOM
    OK, GAS activated.
