Quite Interesting..
Emp_FabEmp_Fab Frets: 24429
I thought we could have an ongoing thread where we could share little interesting things or tips we've learned.  I'm not sure how long it will last knowing you lot though!
Did you know that most car commercials feature number plates that only use characters that read the same in a mirror, e.g. A, H, M, 8, 0 etc so they don't have to shoot a whole separate advert for LHD countries - they just flip the existing scenes.
«1345
  • Motorways are named after the A road they replace rather than in numeric sequence.
  • Emp_FabEmp_Fab Frets: 24429
    Instead of trying to measure water/stock in a measuring jug, weigh it instead.  1ml weighs 1g.  It's a lot easier to precisely weigh a liquid on digital kitchen scales than it is to pour it into a measuring jug, holding it up to eye level etc.
    Whoever is typing a viz style tip right now - stop.  It's been done to death.
  • boogiemanboogieman Frets: 12421
    If you put a bit of pva in with the water when mixing up powder polyfilla, it makes it sticks better and doesn't crack so easily.
  • WezVWezV Frets: 16780
    I was using our new digital scales the other day and realised it was set to ml rather than grams.  That now seems a pretty useless setting :)
  • octatonicoctatonic Frets: 33839
    edited December 2016
    1ml of water weights 1g.
    Plenty of liquids are more dense that water though.
    For instance 1g of vegetable oil equals 1.06ml.
    1g of 15W-40 motor oil equals 1.15 ml.
    I found out about this years ago when I first got into fishkeeping and wanted a 230l tank on a floorboard 2nd floor. I ended up with a 65l
    So you are telling me it's close enough to not worry about it for cooking purposes?
  • I read that the reason Europeans drive on the right is because Napoleon was left handed.
  • If a woman says, "Really? Tell me more!" do NOT tell her more.
    Twisted Imaginings - A Horror And Gore Themed Blog http://bit.ly/2DF1NYi
    4reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • vizviz Frets: 10720
    ^ and if she says, "Is this the fattest I've ever been?",  just run.
  • monofinmonofin Frets: 1118
    When the wife says "do what you want" do NOT buy the guitar you've just been discussing
  • SteffoSteffo Frets: 572
    Those are actually less dense. Not trying to be a smart arse, just pointing out.
  • ICBMICBM Frets: 72619
    By comparison, Mercury weighs 13.5g per ml. If you've handled it (in suitable containers, of course…) it's quite astounding how heavy it is - I think partly because you're expecting a glass bottle of liquid to be at least roughly the same weight as the same amount of water.
  • robgilmorobgilmo Frets: 3583
    Water doesn't stay a constant weight at a set volume, it changes with temperature.
    1 Ltr of water will only weigh 1Kg at 3.98°C , however pressure will also be a factor, so, to be exact , 1ltr of water will weigh slightly under one Kilo at one atmosphere (atm) , however 1 atm will also change with temperature and altitude.
    So , 1 litre of water at 3.98°C at sea level will not weigh the same as 1 litre of water at 3.98°C half way up Everest.
    If you are going to the shop DO NOT say to the missus ''fancy a Kit Kat Chunky''.
    Just don't do it.
    Just don't do it.
  • TTonyTTony Frets: 27681
    Just don't do it.
    Just don't do it.
    And if she pretends not to hear the first time, certainly don't repeat it.
    12reaction image LOL 0reaction image Wow! 1reaction image Wisdom
    A very interesting game to play with a loved one is ''girlfriend rodeo'', whilst making love to your loved one in the K9 position try passionately calling out some other womans name, then see how long you can hold on for. Girlfriend Rodeo.
    Interesting.
    7reaction image LOL 0reaction image Wow! 0reaction image Wisdom
    Interesting.
    Says the voice of experience......
  • ClarkyClarky Frets: 3261
    NYXL strings are better than I expected them to be
