I'm on version 2.12 btw
"You don't know what you've got till the whole thing's gone. The days are dark and the road is long."
file > create backup IIRC
much easier than it used to be
http://line6.com/support/topic/18284-latest-helix-firmware-230—nov-21-2017/
fairly explanatory ?
for some reason my brain read 2:21
2. Use your CURRENT EXISTING Helix application to back up all of your presets and IRs (if you want to keep them). For example, if you're running Helix FW 2.12, your current Helix application version should be 2.12.
If you're updating a version earlier than 2.20 then you need to do it the old cumbersome way. 2.20 and later then you can use the new way which is much easier.
You should have seen wife's face while I inteerrupted I'm a Celebrity with a rendition of Status Quo's Paper Plane through the Helix Plexi preset into the lounge surround sound! I went off piste and improvised a wailing guitar solo and added the fuzz from that preset just to really piss her off.
Now to figure out hat the hell is wrong with the audio interface...
does the software monitoring work in the DAW?
i dont know those interfaces though so beyond that I can’t really help
i tried putting it on a parallel path but the auto sense still puts the entire chain at 10ohms.
setting the input at 1m ohm makes everything sound great but the fuzz is too bright
i think there is an idea scale to fix it by maybe letting the fuzz change the impedance when it is on
