Boss answer to helix - fx 8 - headrush finally released
14567810»
  • althyalthy Frets: 92
    What really bugs me is the absence of reverse reverb along with digital delays with clean vibrato type mod in both the helix and gt1000
  • DominicDominic Frets: 16146
    Yeah,it's a bugger getting by without the old reverse reverb
    I often find I wake late at night screaming in terror over the lack of reverse reverb in the helix
  • impmannimpmann Frets: 12674
    I often find I wake late at night screaming in terror over the lack of great effects in the helix
    FTFY ;-)
    FTFY ;-)
    Hence the pile of moogerfoogers and my pedal board.
    Still, legacy effects are on the way. Looking forward to that
    I see the output options include options to link to Boss/Roland amps like a JC-120, Blues Cube, Waza, Katana etc. Could be good if you like Boss effects.
  • Fretwired said:
    I see the output options include options to link to Boss/Roland amps like a JC-120, Blues Cube, Waza, Katana etc. Could be good if you like shit bland tone.
    FTFY
    FTFY
    True .. Boss don't sell many effects pedals and I can't think of a pro which uses one ..
  • Fretwired said:
    FTFY
    zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
  • ClarkyClarky Frets: 3261
    andyoz said:
    Manual etc are online now apparently.
    Is this here it mate?
    https://www.boss.info/global/support/by_product/gt-1000/owners_manuals/
    read them..
    now I want to try one
    couldn't find anything about reordering external pedals from send return 1&2, anywhere in the signal flow, in this manual. did anyone spot that kind of info?
    If it's like the GT-100, then there will be two effect blocks for send/return (the GT-100 has just the one). I think you can see them on the diagrams -they look like a block with one up arrow and one down arrow, one marked 1 and the other 2.  You highlight the block and move it left or right, like any other effect block. There'll probably be a send level and a return level inside the block so you don't overdrive the pedals you're sending to and don't clip the AD conversion when the signal returns. That's how the GT-100 does it, anyway. I'm sure the Helix does it better, though - apparently it always does.   ;)
