If they just had the Jason sadites style frequency split and boost thing into one block, id be a happy bunny.
I’d also love a plugin interface that didn’t use sideways sliders but it’s not likely with the design philosophy with integrating with hardware. I personally dislike it as far as a plugin UI goes, but I use it anyway because it does cool stuff.
I personally find the octave-down (in addition to the dry signal) just fine in the Helix, at least for adding balls to single-note riffing. Better tracking would be nice, but it's not a dealbreaker for me.
Polyphonic pitch shifting of course
BE100 clean seems like low hanging fruit as do the Lonestar Clean channels
L6 link 30 band EQ (like on M20D)
Snapshottable toe switch between exp1 and exp 2 to let me use it as a Volume boost and a Wah
But tbh that’s nice to haves, I’m actually pretty sorted as it is. I only use 6 of the amp models and 2/3 of the cabs
that would let me use a send out to an amp and control it with the Volume for monitoring while not affecting FOH
I can do it with some routing to use the 1/4 outs as well but it uses up a path
other than that it's all a bonus for me, does all I need, and more
Eqd Speaker Cranker clone
Ordered! Cheers for the heads up!
I received an email confirming the Helix Native order that said "If you purchased a digital download, you will receive an email with download instructions"
I haven't received the 2nd download instruction email yet. Any idea how long it usually takes?
Not sureif that will work, as I have previously used the trial version on Native when it cam out before I purchased my Helix LT.
EDIT: They replied & are checking this with their webshop & will get back to me.
if your account has been linked to the purchase the trail version is the same as the full version
The only difference is when you start it up it checks your account to see if you have bought it not
Olaf Schildt is on the case...
Edit: All registered & working well now!
Cheers for the advice though all, much appreciated.
Would the Power Cab be able to handle bass in FRFR mode? Obviously it isn’t going to be an 8x10 but would it be enough at least for stage monitoring? Anyone tried it? Not much chat on the net so far
