And if the owner genuinely cant be arsed to switch it off, flip the bird at them!
I apply the Mark Twain attributed quote, " Never argue with an idiot. They will drag you down to their level & beat you with experience"
Also Highway code Rule 242 states "You MUST NOT leave your vehicle or trailer in a dangerous position or where it causes any unnecessary obstruction of the road."
Given that you have transgressed the double yellow ruling, you are arguably compounding your offences
I dunno Clint, some might say the S+W 500 is a bit more than that ancient Remington you have there.
Might be able to take down a BMW X5 with one of those.
The quotes were actually directly taken from the Government website, so the capitals were their's not mine :-D
https://www.gov.uk/guidance/the-highway-code/waiting-and-parking-238-to-252
Unless you shoot 44 magnums into Range Rovers?
It was a superb vehicle .
"That's all I gotta say 'bout that."
So you are saying you don't know the Highway Code!
Without looking it up, when you come to a cross roads, you want to go straight over, the car opposite is turning right, who goes first?
Technically, you have right of way if you're going straight on. But since you both have to stop anyway, I think it's better to let them go first if they can see best in each direction on the main road, or if the road they're turning out of is narrow enough to make it easier if they're not in it, etc...
Edit - just to add, its a marked cross roads and both cars are stopped at the give way.
https://www.learnerdriving.com/ld-system/driving-lessons/crossroads.htm
"The general rule for priorities when emerging from crossroads is that right turning traffic should give way to oncoming traffic. The vehicle with the priority in the following examples is the same as if the two minor side roads were one major road, however do not assume that the other driver will comply."
But the important thing is to pay attention to the other driver and *not* assume you have right of way.
