Legionreturns builds a new studio... an epic tale of mishaps and glory
  • spark240spark240 Frets: 2084
    I don’t see any issue with the data cable, although I may have used an external grade cable rather than Cat 5 in conduit, ...the conduit may get brittle eventually and might crack.
    A couple of points you might want to note -
    1. consider and earth pit for the rod , this will retain access to the connection when complete, also for anyone testing the installation in the future might want to Put a notice at the house DB stating it has a 2nd earth connection, otherwise they will never be able to fully isolate.
    2. For what it’s worth you can get acoustic and fire rated Putty pads , these go inside the socket back boxes for additional protection,
    looking great though !
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • LegionreturnsLegionreturns Frets: 7965
    Update time...
    The last couple of days have been foot to the gas to complete the boarding and prepping, before the plasterer started the skim today.
    I'll assume that nobody is interested in watching pictures of plaster drying, so the next update will be friday, when the electrics go live.
    Here's the boarding finished and taped, ready for skimming:
    and today the plasterer did the ceiling and first two walls. Should be finished tomorrow.
    Should be able to start painting in a few days! :D
    Just by way of a quick look back...here's what it looked like just 3 weeks ago...
    I did like your workbench :(
    Feedback
    It's currently in the shed, and I may clean it up and install it in the other garage :D
    Looking good bud....
    Mac Mini M1
  • robertyroberty Frets: 10893
    Yeah man looks like proper little noise cave. Great work
  • PolarityManPolarityMan Frets: 7287
    Just checked back in here for the first time in a while and its looking great, I remember when the plaster went in one my garage conversion it goes to suddenly feeling like an indoors building rather than an outdoors one.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Most of the electrics were connected up today. Just the armoured core and earth to get in to the consumer unit, and outside light to connect.
    Light fixtures look good on the side walls
    Here's the consumer unit in place, just above drummer's corner!
    Finished on Monday, then I'll start painting.
    Ouch...is that a split DB....consider individual RCBO on each circuit,  at the moment it's one out all out....well half out at least.
    Also wondering about the Dom / Studio / clean circuits....meaning what?....just separate wired?
    Mac Mini M1
    edited May 2020
    I'm not actually connecting it up. Got my proper sparky, who specialises in music venues doing it.
    I've got 4 circuits;
    Lights
    Domestic only (Fridge, kettle, Hoover, phone chargers etc)
    Studio is for instruments / amps etc
    Clean is purely a spur for my recording PC and rig and is just that one double plug.
    I know the board has two sections; a regular one and a critical one that keeps going if something else trips. There are obviously breakers on each ring too. It's pretty modern apparently, and he chose it. The whole studio comes off a 6mm armoured core from the main house, and has a separate earth spike buried outside.
    Yeah it’s current spec....though if the supply from the house is also RCD protected them you have no fail safe at all, if an earth fault develops in the studio then you lose the lot.
    You could help this case by selecting different rated RCD devices to give some discrimination, but to be honest it’s costly.
    one last thing, did you say the house was being rewired as well?.....Have they advised you about the use of AFDD ?.....this is an Arc fault protection device now recommended by BS7671 for various reasons, in your case it would be mainly protection of high value equipment against fire,
    I hope ŷou appreciate I’m just trying to help you get the best install for your money, not having a pop at the spark !....
    Mac Mini M1
    Two exciting milestones today.
    Firstly, the electrics are done and signed off
    Really pleased with the lights I picked
    And the outside light is pretty good too!
    I also got most of the mist coat on the walls this afternoon
    The white changes everything! Once the second coat is on it'll look great.
  • mrkbmrkb Frets: 6818
    Wow, looks great. I can’t work out the layout, is the single door on the side, or the rear of the garage? What are the interior dimensions now?
    Karma......
    Ebay mark7777_1
    It's a little under 5m square. The door you can see is the side door in from the garden, the big garage door is now bolted shut and behind the long flat wall. The pillars with lights on are the sides.
    Easily room for a full band plus my storage, desk, fridge and home theater stuff.
    “Home theatre” ?! Is that your collection of pantomime costumes? ;)
    Karma......
    Ebay mark7777_1
    Time for another mammoth update...things are really starting to come together.
    First off, my tame chippy arrived to do joinery magic. Skirting boards, architraves, and of course, hanging Lemmy properly for me!
    While he's been doing that, I took the time to start getting things on walls.
    Speakers and stands
    A heavy, sound dampening curtain to cover the wall that I will be using as a cinema screen, as I can't use any other acoustic treatment on this one
    Then it was time to start painting the new woodwork...
    Today I started acoustic treatment and some of the final wall finishing
    Oh...and I put up the LED lights for background lighting when watching a film or playing Xbox on the giant wall, or to do sound to light when I have clients in.
    Then, finally, the moment had come for the trickiest job; lining up and applying a round vinyl decal, with almost no straight lines to level it with, to a rectangular wall! Very happy with the result!
    And we finally got Lemmy hung! Many thanks again for the donation @Sasquatch_Bob ;
    We're just fiddling with the tunnel sides, to link the inner and outer door, and then the floor will be going down. Should be tomorrow.
    Looks Great dude !....A tip for that green led....stick a timber Batten ( about 30mm deep ] on the ceiling about 100mm from the wall all the way round.....it will make the led effect loads better...
    Mac Mini M1
    I'm aware of the effect and agree it would look great, but finding the damn hat rails to screw them too now would be a nightmare, and as they only run in one direction, the sides would be near impossible.
    edited June 2020
    Use the proper tool! use “no more nails”!
    Karma......
    Ebay mark7777_1
