i'm still to decide on knobs, standard amber gibson style is my backup
Instagram
I think the guard is perfect as it is. It just needs a pair of old bakelite knobs to go with it.
(I still think it needs the triple diamond tailpiece too! )
As for the guard may be try gold/silver/bronze foil against it see if it pushed the light back a bit more or just black card to see what it would look like black painted. I don't like it as it is but worth the experiment.
its not too far off the aesthetic I have in my head (simplified gibson), and the tailpiece is similar to the Duesenberg one. We will see what i actually prefer once the part turns up
Instagram
I suggested foil originally as it is what was done on a lot of older guards, usually why they look too bright.
I went for medium tort on this one and part of me is wondering if the darker version would be better. Ideally i would want a bit more red, but not too much red
worth remembering the guards do often clash a bit on this style
Instagram
The colours on your finish and pickguard are not hugely different to those on the Cromwell archtop. On the Cromwell, it all matches OK. But the Cromwell's pickguard pattern is much more defined and precise.
Perhaps it's just the cloudy pattern that's "off" on yours?
it takes actual light it change it
but it is kinda porous so i might look into tinting it a little
Instagram
Instagram
Rudddy Marvellous !!!!!!!!!
Feedback
Instagram
this
https://www.etsy.com/uk/listing/554592754/3mm-w204-blown-and-dark-brown-marble?ref=shop_home_active_24&frs=1
and this
https://www.etsy.com/uk/listing/240113210/3mm-w308-dark-brown-white-and-drown?ref=shop_home_active_25&frs=1&crt=1
will see how the sheets look when they arrive and put this decision off for now
Instagram
Instagram
would be my preference if I was having this custom made myself.
Black just seems so plain, but I might knock one up at some point
Instagram
Instagram
