Axe_FX II Rigs, or: How I Learned to Stop Worrying and Love Digital Modelling.
  • guitarfishbayguitarfishbay Frets: 7964
    edited January 2016
    Honestly I wouldn't place too much value on patches from the exchange.
    My advice if you want to get up and running quickly is to use an amp you're familiar with and to check out an impulse pack from Ownhammer or Fractal that has IRs of a speaker/mic combo you are familiar with.  The stock IRs are fine but they cover a lot of ground, so if you're looking for a specific sound from a certain cabinet you might find it easier just to have more choices for IRs of that cab.
    I find anything I know how to use in real life is pretty quick to dial in doing that.
    There are a lot of options for dialing in an amp but the core controls are by far and large the most important - gain, bass/mid/treble, master volume, and resonance/presence.
  • ClarkyClarky Frets: 3261
    prh777 said:
    Hello chaps. It's a bit hard to search for this in the thread so apologies if it has already been asked but here goes.
    I understand that the xl has more patches , lower noise floor (unnoticeable it would seem) and more memory. But what is your take on getting a 2nd hand II vs a new XL+. Former seem to be available for around 1400 whilst the latter is closer to 2100 at today's exchange rate.
    My main concern is that patches for the XL can't be loaded on the II and wanting to be up and running quickly (won't have huge time for twiddling initially) means I won't be able to access the new shared patches on the xchange.
    I'm generally accepting of the depreciation aspect and he price difference. I am more concerned about subsequently wanting to upgrade and having to sell the II because it didn't suit. Appreciate this is all subjective but would value your input on the differences/factors vs advice on making choices....
    I wouldn't be thinking about getting the II particularly but someone has offered me one in trade against my mk v.
    Thanks in advance.
    I have an Axe-FX II mk1…
    the differences between the models mean so little to me that I don't feel the need to get either a mk2 or an XL..
    where it matters [tone, fx, control features etc] they are all the same..
    the XL does have some advantages..
    - instead of 384 presets it's 800 and something I think..
    I've never found 384 to be too small, and even if it were, you can save presets on your mac / pc.. so there's not really a limit in that sense… I could never imagine playing a gig that needed more than 10 presets?? lol..
    - the XL has a few more fx blocks that have X and Y sides that the mk1 / mk2.. but I'd personally not feel the need to part with that much cash just to get them..
    if I ever needed to get a spare Axe-II, I'd get a mk1 or mk2..
    basically because I'd have to [so I can load them both from the same image]
    if money were no object would I replace my mk1 with an XL?.. I doubt it..
    if money were no object and I didn't already own an Axe-II I'd most likely get the latest / greatest..
  • mrkbmrkb Frets: 6962
    The XL can also store many more user IRs (Cabinet Impulses) - I think the II is 100, the Xl is 1024 - but again a PC can be used to manage and blend these - so storing loads in the unit isn't a huge advantage.
    Karma......
    Ebay mark7777_1
  • Anyone seen this post from Cliff?
    "We are working with Joe Satriani to make some models of his amp and when that's finished we'll release 1.07. It's going to be a few weeks so you can give your F5 key a rest."
  • I'm assuming that'll be the Satch JVM but it'd be cool if they did the JSX too.
    I have many hundreds of IR's in my Mac.. and I've used cablab to make all kinds of mixes etc..
    yet I still find myself using the 4x12 TV Mix with the 4X12 AX Mix.. both of which are stock cabs...
    so... I have a few hundred cabs internal to the Axe [with all user slots filled] and close to a thousand more in my Mac..
    but I only use 2 bog standard ones... lmao..
  • Handsome_ChrisHandsome_Chris Frets: 4779
    edited January 2016
    I'm with @Clarky on the AF2 upgrade front. When I was in a band I never found the benefits offered beyond my AF2 mk1 were anything to get that excited by. A salient point that is missed out in these discussions is the fact that the mk1s actually sound better than the newer variants. They have more soul. The 1s and 0s in the current ones just sound too digital.
    1reaction image LOL 1reaction image Wow! 1reaction image Wisdom
  • prh777prh777 Frets: 143
    I do prefer the sound of vintage 1s and 0s. Should've kept using the dAW on my Amiga....
    have a wisdom for recognising that binary improves with age.. just like valves.. that's how good the modelling is..
    the square waves in the Mk1 wear with time so they get rounded off at the corners so they sound less harsh...
    Thank you all for your inputs. Very useful as always. Cheersd
  • The only reason to go for anything except the original AFX2, is the encoder.  The 2 has an electrical encoder, which starts getting flakey over time.  The XL and XL+ use optical encoders which dont suffer from the same issue.
    This is only a problem if you edit a lot from front panel though - and encoders arnt expensive to change (if G66 wont do it, which is unlikely).  Had mine since it was released (replaced my old standard) and never wanted another - bar that odd encoder issue.
  • paulmapp8306paulmapp8306 Frets: 850
    edited January 2016
    Quote from Cliff, in a thread where the OP cant get a good sound using a real amp and cab.
    "Weird. I'm actually using a Matrix into a 1x12 right now and it sounds better than the amp I'm modeling."
    So - firstly, yey for Matrix amps into cabs - and second..... Whats he modelling thats 1x12??
  • Not sure, there's been a recent focus on Vox types so possibly something relating to that?
  • GadgetGadget Frets: 897
    edited January 2016
    Quote from Cliff... it sounds better than the amp I'm modeling."
    Do we want 'better' than real? I mean, isn't that a contradiction in the world of modelling?
    I think, therefore.... I... ummmm........
  • Of course not - I think what he means is that the audible result from the Matrix/Cab was more pleasing to him than that from the real amp.  He will aim - with the modelling process - to get it to sound the same (both FRFR and for use with amp/cab - which is why he checks/adjusts both ways), but that means in his opinion, he is making the sound worse than it could be even if its more acurate.
  • DefaultMDefaultM Frets: 7395
    Please can someone explain how to set up a patch for fx only 4cm with a tube combo?
    All I've done so far is to put a single fxl block in there and then put drive to the left and delay to the right. The drive is just ridiculously loud though.
    edited January 2016
    Here we go again..... QUANTUM 2 anyone??
    recent post:
    Also our upcoming Quantum 2.0 firmware features significant improvements to the very amps you mention.
    from cliffs own keyboard.
  • Wonder if the Satriani involvement has anything to do with that?
  • Wouldn't have thought so. Artist insolvent regards rig settings a normal a point increase. Full fw revisions are normally reserved for more major amp modelling improvements.
    The amp in question the thread was about is a vibroverb.
    Quote from Cliff:
    Have a hard time taking that sort of thing seriously.
