I have some IRs taken from a Yamaha SPX90. One particular setting (Reveerse Gate, L8, room size 20) pretty much is the classic MBV reverse guitar sound.
Could I load that into the cab block and use it as a reverse reverb sound? I know it sounds utterly ridiculous but if it would work, then that would be a huge thing for me.
Hadn't considered that. Could you put the Kemper in one loop and the fx8 in another for a huge, massive uber modeller?
If someone has already done this, I wanna see a helix profiled by a Kemper
On its way mate, and due today !
Does your Helix colour the sound plugged into an amp ?
I appreciate there is always adjustment and the nkering needed with digital stuff; out of the box straight into the Rambler (with no amp block) the amp is 'dulled'.
Any setup thoughts and advice ?
If you want it to sound like your amp input then probably needs to be set to the 1Meg setting.
If you leave it on 'auto' it sets the input impedance to model the impedance of the first block in your helix chain
So far I've done the firmware update to 2.20. Is it just me - I find this sort of exercise pretty stressful. As it happens, the update all went very smoothly.
I had a bit of a scroll through the presets, but I'm going to really get stuck into it over the weekend. It looks good - like a black monolith.
Ugh, no scribble strips?
Eqd Speaker Cranker clone
