Helix LT is now available for order. Cut down version - ish.
  • That Helix UI is superb, to be fair!
  • HeartfeltdawnHeartfeltdawn Frets: 22352
    Here's a really stupid question and it's about the IR files.
    I have some IRs taken from a Yamaha SPX90. One particular setting (Reveerse Gate, L8, room size 20) pretty much is the classic MBV reverse guitar sound.
    Could I load that into the cab block and use it as a reverse reverb sound? I know it sounds utterly ridiculous but if it would work, then that would be a huge thing for me.
  • Here's a really stupid question and it's about the IR files.
    You could load it but it would be truncated to 2048 and therefore reaaaaally short. So not really no
    Oh well. I thought it unlikely. One day there will be a pedal out there that can load lengthy IR files that isn't the Logidy :)
  • guitarfishbayguitarfishbay Frets: 7964
    edited April 2017
    I don't think any of the modellers on the market currently loads long 'reverb' style IRs.
  • SporkySporky Frets: 28872
    But it might still sound interesting.
  • simonk said:
    So, as a FX8 and Kemper owner, I've ordered a Helix LT !
    Now, let's see what's all the fuss is about ;)
    I love my Helix, like my FX8 and like my Kemper. What I really want to do though is stick all 3 in a blender and create a bastard child touting the best of all three.
    The Helix's interface and simplicity teamed with the best sounds of all three plus the ability to profile or load amps would be, well, killer.
    Put your kemper in a helix loop. Then you have blended those two. Kemper profiles with helix routing and fx. Those FX loops make helix a beast.
    Hadn't considered that. Could you put the Kemper in one loop and the fx8 in another for a huge, massive uber modeller?
    If someone has already done this, I wanna see a helix profiled by a Kemper :)
  • TeetonetalTeetonetal Frets: 7818
    Well @Wazmeister will soon have all 3.... Sounds like a challenge
  • Cabicular said:
    keir said:
    Vaiai said:
    Yep - manual comes on a Helix branded USB pen in the box - will put it on Dropbox
    https://www.dropbox.com/s/w7msxqsahj5maf9/HelixLT_OM_English_v210_RevB.pdf?dl=0
    Top man - thanks mate ;)
    The manual on the stick is for the old firmware gents, you can download the new one from the website :)
    Got a link mate ? I couldn't find the LT version.
    There isn't a specific LT manual
    but it is the same engine with a slightly different UI to cope with the scribble strips
    LT manual is on our website here.
    Chief Product Design Architect, Yamaha Guitar Group | Line 6 | Ampeg
  • @Wazmeister Did you get it yet?
  • WazmeisterWazmeister Frets: 9629
    On its way mate, and due today ! :)
  • Brilliant, enjoy! Bet you can't wait!
    So, initial set up question...
    Does your Helix colour the sound plugged into an amp ?
    I appreciate there is always adjustment and the nkering needed with digital stuff; out of the box straight into the Rambler (with no amp block) the amp is 'dulled'.
    Any setup thoughts and advice ?
    Check the input impedance setting.
    No.
  • TimmyOTimmyO Frets: 7600
    The input block has multiple impedance settings.
    If you want it to sound like your amp input then probably needs to be set to the 1Meg setting.
    If you leave it on 'auto' it sets the input impedance to model the impedance of the first block in your helix chain
    Red ones are better.
  • stratman3142stratman3142 Frets: 2211
    edited April 2017
    Got my Helix LT now. So I'm officially a lightweight and not a fatty.
    So far I've done the firmware update to 2.20. Is it just me - I find this sort of exercise pretty stressful. As it happens, the update all went very smoothly.
    I had a bit of a scroll through the presets, but I'm going to really get stuck into it over the weekend. It looks good - like a black monolith.
    It's not a competition.
  • robinbowesrobinbowes Frets: 3057
    Ugh, no scribble strips?
  • simonksimonk Frets: 1467
    But he does have an expression pedal...
