PSA Marshall Origin 20 dropped again
  • GO GO GO!!!!
  • KrisGeeKrisGee Frets: 1304
    Has anyone tried this with a matrix nl cab? Seriously tempted to give it a go but not looking to mess around too much with swapping cabs etc.
  • BarnezyBarnezy Frets: 2209
    Boom!
  • smudge_ladsmudge_lad Frets: 669
    £239 at Peach
    I ordered the combo and it comes tomorrow. I read about people swapping the 10" speaker for a 12" or a 10" greenback. Anyone tried that here?
    My 20watt head has arrived at home waiting for me. Won’t get a Vance to play it tonight though :(
  • JohnPerryJohnPerry Frets: 1622
    Yes, G10 greenback and some decent preamp tubes and it is very substantially better, also less noisy.
  • skippy76skippy76 Frets: 616
    I’ll second the decent preamp tube upgrade. Sticking a JJ ecc83 (12ax7) in the V1 position on my 20w head reduced the noise and fattened up the overall tone a dash (to my ear). Not bad for £13 :)
    ‘I’m looking at a full set upgrade including the EL34s, will update when tested.
  • paulnb57paulnb57 Frets: 3057
    Is it possible to get a smidge more gain from a valve swap? O 20 H...
    Had a quick play through last night, into my 1960A cab. Loved it! Even on 5w, I really couldn't turn it up very much.
    What a great wee amp!
    Will take it along to rehearsal tonight where I can crank it a bit
  • ICBMICBM Frets: 72528
    Not more gain really, but slightly more distortion. If the amp comes stock with a JJ in V1 and Chinese 12AX7s in V2 and V3 (the SV20H does), the first thing to do is swap V1 and V3 - that will give a little more bite and harmonics.
    (The Marshall labelled JJ has red lettering and the Chinese ones white.)
    If you want to try new valves, old-production RFTs seem to have slightly more gain - as well as a really good bright but rich crunchy sound that suits Marshalls better than anything.
  • TwinfanTwinfan Frets: 1625
    You must have had a duff V1, the red label Marshall ECC83s are JJs   ;)
    I've kept my stock V1 and swapped out the chinese high-gain V2 and V3 for a couple of valves with lower gain.  HUGE difference in the amp, reduced the previous thick and muddy mids to classic Marshall sounds.
  • GrahamGGrahamG Frets: 87
    Ordered a 20H last night from Peach,just been notified delivery Today  between 5.00 & 6.00 =)
    which valves did you put in?
    Question for everyone doing the valve swaps - is it easy enough to do, with no prior knowledge of said procedure?
  • PhiltrePhiltre Frets: 4175
    @smudge_lad Take the 5 screws out the back panel, remove the panel and pull the valves out.
    This is what I wanted to hear, lol.
    Just wasn't sure about what I'd heard about matching pairs/biasing etc. Or, is that strictly for power tunes as opposed to pre-amp?
    edited July 2019
    The Origin 20w head is cathode biased so you don't need to do a manual bias. Just make sure the power valves are a matching pair. Also, make sure the valve pins align when replacing. The power valves have a key indent in the socket, so line that up too.
    Disclaimer - I am not @ICBM
    A couple of old Mazdas I had knocking about.  Any decent ECC83s should do though - Tung Sol, JJ, Sovtek etc.
  • simonhpiemansimonhpieman Frets: 684
    I've only done one gig with my 20C so need a few more to dial it in exactly as I want but this sounds like something I'd probably want to do.
    What did you change them for?
    Read my post above yours  ;)
