That said anything can go wrong with any car, don't worry about it and just drive it.
Brits seem to have a bit of an obsession with trad manuals, but honestly the latest dual-clutch stuff is really really good.
Just buy the green Veloster and only worry about reports of problems with the auto box in the unlikely event it actually happens. The most important thing is that your wife likes it . Or at least is saying so just so that this can all be over .
May be he is trolling again with the gear box failure since he was very confident not so long ago.
Either he was trolling then or he is trolling now.
Or you can blame me for that too!
Not sure I'd rush out and buy a 5+ yr old one with >70k which is what this thread is about.
What seems to kill dual-clutch boxes isn't necessarily high mileage, but driving them too hard, using sport mode and/or revving it hard from cold, manually holding it in lower gears for long periods, etc etc.
(Does the Veloster have a sport mode?)
Worrying about reliability is one aspect, but dual clutch gearboxes vary hugely in their “feel” and how they affect your driving experience (for better or for worse).
The DSG system I had in my old TT was excellent in that it was almost invisible, could be switched between different modes, and also had a full manual option through the gear lever or the paddles on the steering wheel. I’d not hesitate to recommend that. But not all dual clutch auto systems are created equal ...
He's been through about a dozen cars in the last year or 2 from Porsche 911 to Aston Martin to BMW M1 to McLaren (3 of them), made a killing on bitcoin.
The Veloster uses a DCT/DSG.
Given that it's not very powerful I'd imagine they've used a dry rather than wet model.
Essentially, if you drive them hard for many miles, yes they can give problems. Otherwise they are fine. A DSG is more complicated than a manual gearbox so yes you could argue that it could be less reliable.
Provided there's no issues with gear "sticking" (indicating a problem with the selector mechanism which is generally an expensive fix) I wouldn't be unduly concerned
Everything always needs improving. Having driven a Mk5, 6, 7 and 7.5 Golf I can tell you they got better with each generation. I'm not going to hold off buying one until the Mk 10 comes out in 8 years on account of that though.
Basically, I've insisted on new discs all round as they were flagged as advisories on the most recent MOT and a slight imbalance in the front brakes being resolved (though that's most likely due to worn discs anyway). The dealer is also putting it through the body shop to get a few tiny marks sorted.
All being well, I will be picking it up on Monday 29th.
