TC Electronics Plethora pedalboard.
  • And one comment they made said they're looking into amp channel switching.
    Which is fairly nice.
    Bye!
    Surely that requires hardware changes though, which I would have thought was a more difficult proposition than adding new effects types...
  • tone1tone1 Frets: 5175
    Is there a Univibe?
    Depends on the topology. It could be something like "okay, there is now an option for the RIGHT output to be a switching output, but your main signal can only be mono" - but I honestly don't know.
    Bye!
  • What I'm curious about is what midi functionality there is built in. Can selecting a board send a program change, and can you string together 5 boards across the switches for 'snapshots' style functionality?
    How far does it go to being the "command centre" of your board. Could you get away without having a midi controller?
    Wont know that until the manual is available I suppose.
    Bye!
  • tone1 said:
    Is there a Univibe?
    By the sounds of it they're still porting over some of the other toneprint pedals. Helix phaser and Viscious Vibe being two of them.
    Bye!
    tone1 said:
    Is there a Univibe?
    Ta... :)
  • monquixotemonquixote Frets: 17652
    And someone asked about drives and TC say "Not yet. But there could be".
    Which is also nice.
    It does have the Hypergravity compressor so with the level up and the ratio down you could use it as a boost.
  • And someone asked about drives and TC say "Not yet. But there could be".
    Which is also nice.
    Yep! That'd be partly my plan!
    Bye!
  • So that'd be an option, assuming the Plethora had some kind of ability to send midi PC's by itself without needing an additional midi controller.
    Bye!
    I would guess that although their midi thru forwards received midi it is actually processed in the unit to respond to incoming midi first and as such could be turned into a midi out in software.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • Creed_ClicksCreed_Clicks Frets: 1389
    edited February 2020
    Interesting demo video. I had been thinking of going all in on a Line 6 Helix FX later this year, but this could be a winner for me. I could still use my few drives, and boost I take it, with this.
    As a noob on digital, just wondering how you could make the comp and chorus for example, go "before" the amp, and the rest in the loop. I would imagine it's something silly my brain can't figure out yet. Just bought a Boss DD8 too :(
    Maybe it's the shiny shiny trying to tempt me....
    Gulliver said:
    Double post - the quick swap feature of just holding the 2 footswitches to swap pedal order looks great.
    I don't think it can do presets though, so I can't load a board with 5 pedals, and create presets using those 5 pedals...  I wouldn't ever use it that way, but I bet loads of people would want to be able to do that.
    That’s exactly what I’m after. Otherwise I’m back to my Nova System. I have a lot of backing vocals now so hitting just one button wherever possible to change everything is my goal.
    But this is exciting. I think if they develop this concept and bring out a well priced hybrid of a Nova/G system with say preset mode, two insertable loops for drives. Sockets for exp pedal and bombproof construction. That’s game over for the HX effects and possibly those LT users who used amps. Also a stand alone tone print system would be a great M5 replacement. Although maybe this is.
  • english_bobenglish_bob Frets: 5162
    You would use the insert loop on the Plethora. The loop send goes to the amp input, then the amp's effects loop send goes back to the loop return on the Plethora. The Plethora's main output then goes to the amp's effects loop return.
    Working out placement of the effects loop within the chain would be done within the Plethora.
    The Line 6 FX could do this I take it? As in, presets, and each one would be a different chain of effects?
    At the moment, my effects loop is a reverb, Boss DD8 and a Line 6 M5 for activating all the quirky effects I'd rarely use but nice to have them when I need them. Maybe if it ain't broke....
    Youtube comments from TC hint heavily that smaller er... Plethorae may follow at some point.
    Also @WiresDreamDisasters one of TC's replies describes it as having MIDI OUT rather than THRU.
  • Youtube comments from TC hint heavily that smaller er... Plethorae may follow at some point.
    Hopefully I'm wrong about what I said earlier and hopefully either:
    1. They've got midi CC and midi PC transmission per-switch and/or per-board selection.
    2. They've got plans to implement as such.
    I could really see myself moving to this for a portable board if it had the above. I hope it has regular channel switching possibilities for you cats too, but that wouldn't help me much on account of my amps requiring midi.
    Worst case scenario though, maybe I could add a small portable midi controller to it. The ES-5 is smallish but you can get smaller.
    Bye!
  • Dimensions btw: 298.5 x 116 x 53 mm (11.8 x 4.6 x 2.1")
    Bye!
  • crunchmancrunchman Frets: 11462
    I'd be interested in that, but not the big one.
    It's not going to be better than the Big Sky, so I'd have no use for the reverbs.
    I also don't want to be too dependent on a TC product as I've had too many reliability issues.  A single, or maybe double pedal, that could load any toneprint would the ideal.  It would allow me to get many more options while making my board no bigger.
    On this front what I would say is that for at least 10 years now we've been at a flavour versus flavour point rather than a quality versus quality front.
    There are obviously specific quirks to each brand and each model. But I think the TC delays and reverbs are absolutely up there with the Big Sky. Same with the Digitech stuff, Boss stuff, MXR reverb, etc.
    I absolutely wouldn't consider this myself if I thought the delays and reverbs TC gave you were total cack - they're more important than the amp to me a lot of the time! :lol:
    Bye!
