However, the reality is clearly different..
The difference between the Neural and the AxeFX is a lot less than the difference between you and Rabea.
But ultimately I know very little of this world.
If it's someone like Boss people aren't going to be that silly.
Pretty much any modern piece of gear can be made to sound good and this a required skill for any pro.
However for most amateur musicians with limited time you tend to want something that sounds good out of the box and for the things you want to play rather than changing your playing / approach / other gear / production around it to try and best fit a piece of equipment.
Glenn Fricker's absolutely explicit about this - he has product demos and reviews that are sponsored, and he has his separate Patreon-funded reviews where he can be honest about it.
On top of that, if a YouTuber gets something in that's not quite right, they have an opportunity to work with the company to make it better - and that relationship can be worth far, far more than the unicorn of a sponsored video slating a product.
With that said, there's very little truly shit gear around these days.
Yep in the example of Elmo he has done 2 or 3 follow up videos on the amount of crap he's had about saying he doesn't like the Marshall Code
It's different in gaming - there are always extreme non-disclosure agreements and embargo limitations. I've never really seen that to the same level in music tech. There's a lot of faith and trust going around, much more so than the cut-throat world of gaming.
Look at Cyberpunk 2077 and their piss-take agreements they made all of the Youtubers sign up to. They were prevented from using their OWN gameplay footage for their reviews, and had to use footage provided by the company. Total garbage move from a reviews perspective.
That doesn't happen in music tech to my knowledge.
